whinning noise when i start it up?
It has been like this for the longest time now. Right after you start it up, and for about 5 to 30 minutes when you are on the gas at all there is a high pitched "nehneneneneh" sound coming from the engine bay.
At first I thought it was the belt, as it was getting worn. So I replaced it and it didn't fix the noise. Then later on I had to replace the Water Pump and thought it could maybe have been from that, but nope. Does any one have any idea's on what it could be?
two possible items. you might have glazed your pulleys from the last belt and need to clean them with a wire brush to get the old rubber off. clean you pulleys and re-tighten your belt. Could it be a bad alternator bearing?
It may be organic.
Are yours, or any of your neighbor's cats missing?
Miniature ponies?
Must be your blower.
http://videos.streetfire.net/video/m...ine_168081.htm
Seriously check your belts.
