without goin bonzi, has any-one done a mini-tub on a 65-66? while I'm in their doin trunk work, I thought it might be a good time to widen the rear tubs. It looks like I can move them inward about 3/4- 1" without messing with the existing leaf spring locations.
Ive done it and it is a PITA. But it is worth it to me because i really wanted the wider tire look. I mean how else am i going to get the front end up in the air?
yeah, i was thinking that would be a lot easier and cheaper, how wide was the strip you welded in?
edit: do you also still have the rear seat?
Im not sure how wide the strip is. It is not the same width all the way. I mounted it flush with the frame rail. Had I had it all to do over again I would buy a new frame rail and move it in a couple more inches. wouldnt take much more work. the trunk is easy. cut it off from the inner wheel well and trim the bottom of it for the wheel well to slide under and re-weld it. Ill take more pictures for you but my car is at the body shop.
