WHO knows how to adjust rocker arms....
i got a 1969 with a 302 engine. My rocker arms are the ones with rails...the pushrods sit in a large hole with no sorta guide as the rocker arm kinda cups it so it stays in place.
now how do i adjust these suckers....some people say feel the pushrod while cam is at lowest position and then tighten 1/2 turn after no more play in pushrod...
while others say..
torque the nut 23lbs
what is the correct way???
while others say..
i just wanted to make sure, look what i found....
http://www.summitracing.com/landing/...orquespecs.htm
non rail:
rail type:
instead of small holes in the head the tip gets the rocker centered. this typ is non-adjustable the only way to fix adjustment problems with them is to order different length pushrods
rail type:
