My engine wants to jump out of my car
ok now that you stated the rubber splits....they may be broken
the rubber is split on the passenger and driver side right in the center...it looks like there are two pieces of rubber on either side just resting on each other
does that sound normal...or does that sound broken
^^^^^ What he said. Since they are broken you can either put new stock mounts in (Cheapest), or you can upgrade to motor mounts that can't separate. You can also drill a hole in the new mount through the 2 metal plates and the rubber and insert a bolt so that they can't separate down the road.
well...just one more thing i gotta fix
thanks guys i appreciate it
i think ill stick with stock mounts, because as you said they are the cheapest. im building a stroker motor right now so i can always upgrade mounts when i pull this motor for the new one.
any recommendations on where to buy them? i normally go through cjponyparts
