Anger and Frustration - Trouble starting at night - 68 coupe 302
Old 05-25-2009, 07:43 PM
f0rdman
f0rdman's Avatar
Exclamation Anger and Frustration - Trouble starting at night - 68 coupe 302
Hey guys,
I have a 1968 coupe 302 with stock heads, 650 thunder series edelbrock carb [converted to manual choke], edelbrock air gap intake manifold, comp 268 dur cam, stock points distributor, and a msd blaster coil.
I listed all of my engine mods because I am stumped as to why this brand new engine with barely 400 miles on it will not start at night.
I've pissed off the neighbors at 3 of my friends homes because of my car backfiring. The only, last resort, way of starting it is having the choke completely closed and holding my foot all the way down on the gas. It will start if I do that but obviously sounds like a cannon because I have 3 in pipe and 2 stage flows. To make matters worse, I think my new starter is beginning to fail.
I know the problem isn't with the accelerator pump or the fast idle. Any help with troubleshooting will be much appreciated. Thanks
f0rdman is offline
Old 05-25-2009, 07:48 PM
67mustang302
67mustang302's Avatar
What's the timing?
And you should really ditch the points.
67mustang302 is offline
Old 05-25-2009, 08:01 PM
KMatch
KMatch's Avatar
My first thought on a hard start at night is water in the distributor cap or weak points. Other than that, does it actually backfire while cranking - or when you let off the key? If it backfires when you let off the key it likely has no fire to the distributor during crank but gets a 12 volt shot when the key is released to the on position which can lead to a backfire, hardstart problem.
An extremely rich fuel mixture (the wide open throttle while choked) can "sometimes" overcome a weak spark.
Generally, a lean fuel mixture will backfire out the carb. A weak spark, spark at the wrong time or crossfire will backfire out the exhaust.
KMatch is offline
Old 05-25-2009, 08:02 PM
f0rdman
f0rdman's Avatar
10 degrees
f0rdman is offline
Old 05-25-2009, 08:09 PM
67mustang302
Are the points adjusted correctly?
Old 05-25-2009, 08:15 PM
f0rdman
f0rdman's Avatar
It backfires while I am cranking. It only does this at night when the engine is cold. When i initially turn the key it will feel like its starting and the fast idle will make it rev for a split second before it dies or as soon as i stop cranking it. thats with my foot just sitting on the gas pedal with the choke closed. If I push the gas all the way down it will eventually start and also be revved to like 3k.
f0rdman is offline
Old 05-25-2009, 08:18 PM
f0rdman
f0rdman's Avatar
yeah, the dwell is set at 29.
f0rdman is offline
Old 05-25-2009, 08:23 PM
f0rdman
f0rdman's Avatar
It backfires out the exhaust, not the carb. sounds like a .22 :-D
f0rdman is offline
Old 05-25-2009, 09:14 PM
67mustang302
Have you tried adjusting the idle mixture or anything else on the carb?
Old 05-25-2009, 09:48 PM
f0rdman
f0rdman's Avatar
well I have it set so that it runs well during the morning / day. never really fiddled with it at night. I changed the metering rods to slightly leaner. but not enough to make a difference. Any suggestions?
f0rdman is offline
Quick Reply: Anger and Frustration - Trouble starting at night - 68 coupe 302
