How to rig my distributor to get more spark?
I have a 69 stang, had it when i used to live in the US but moved to Europe and brought it with me. Here in Europe we have min 95 octane. I believe this is the reason why I get horrible smells coming from my exhaust. Also get some white smoke when i rev it from idle.
Is there a way I can get a little more spark out of my distributor so that I can burn all the fuel? I tried to adjust the idles but cannot get the mixture to where i want it enough to get rid of the smells and white smoke.
By the way i have a 302 with an electronic distributor.
Any suggestions?
Any suggestions?
it is, cant get a more idle and tuned position, everything is new I rebuilt the engine last month. Just cant get rid of the smell and the little bit of white smoke. Im asking how to get more spark...
Well its running high octane and has been ever since i lived here. My engine is spot on when it comes to timing. Fires at no 1, dead on top dead center and if i turn the dizzy seems to lose its perfect idle. So i guess timing is not the issue. I think its an octane issue. I used to run 95 which is the min here, then i put 98 and smoking got worse. So thats my logic. how can i get more spark to burn the octane.
i read somewhere that white exhaust smoke comes from coolant and/or water burn off in the combustion chamber due to a leaking or blown head gasket, cracked head etc.
seems like black smoke would be more of an "unburnt fuel" symptom.
White smoke: White smoke is caused by water and or antifreeze entering the cylinder, and the engine trying to burn it with the fuel. The white smoke is steam. There are special gaskets (head gaskets are the primary gaskets) that keep the antifreeze from entering the cylinder area. The cylinder is where the fuel and air mixture are being compressed and burned. Any amount of antifreeze that enters this area will produce a white steam that will be present at the tailpipe area.
Black Smoke: Black smoke is caused by excess fuel that has entered the cylinder area and cannot be burned completely. Another term for excess fuel is "running rich." Poor fuel mileage is also a common complaint when black smoke comes out of the tailpipe. Black smoke out the tailpipe is the least cause for alarm. Excess fuel will usually effect engine performance, reduce fuel economy, and produce a fuel odor.
