Pertronix Question
Pertronix Question
After about 8 mos, it seems the module failed. I'm getting spark at the coil, but no spark at the plugs. Silly questions but could this be anything else bu t the module? Plugs and wires are the same age.
EDIT: Carb is splashing up fuel but no "backfire" or smoke, just fuel. Of course, wihtout spark, what else would I expect.
if the module failed then you should have no spark at all.
How did you test for spark at the coil and was it a bight blue or red/orange in color?
I guess its possible that it could generate a weak spark that isnt powerful enough to get to the plugs.
Might want to check the rotor and make sure there is nothing on it like dirt or a dead bug or some crap like that.
-Gun
-Gun
I pulled the plug at the COIL, not the dizzy, just enough to see the spark. I was definetly a red orange and not what you would call BIG or blue.
The coil is a Pert Flame Thrower installed the same time in August, 08. Is this telling me the module itself is ok? I guess I'll check the cap/rotor, just to eliminate them. Anything else to check? Thanks for your help!
Disconnect the coil secondary at the distributor and hold it close to ground (bolt on the head or accessory bracket). That is really the only way to test for a proper spark. If it is nice and hot, then try the same with a couple different plug wires. Right now, it sounds like the cap or rotor to me.
AMAlexLazarus
AmericanMuscle.com
10-02-2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
treesloth
09-28-2015 07:03 AM
