REPLACEMENT WHEELS
REPLACEMENT WHEELS
I HAVE A 66 MUSTANG CONVERTIBLE-QUESTION-ALL THE WHEELS INCLUDING THE SPARE ARE OUT OF ROUND-SLIGHT SHIMMY COMING THRU MY STEERING COLUMN BETWEEN 40 AND 55 MPH-HAS ANYONE REPLACED THEIR WHEELS WITH NEW REPLACEMENT WHEELS FROM CJ PONY PARTS OR ANY OTHER PARTS SUPPLIER AND HAS THE RIDE IMPROVED AND THE SHIMMY BEEN ELIMINATED-THANKS-TOM
A shimmy can be caused by a lot of things.. bad wheels, bad tires, alignment, improper engine/driveshaft balance, bent rear axles, etc, etc, etc.
Take the car to an alignment shop and get it properly aligned. At the same time they can balance and tell you if there is an issue with the wheels. If it persists take it into a driveline shop and have then check the driveshaft. If it persists still you move along to the next thing and have checked. Its a hard lesson dishing out good money for new wheels/tires and still have the shimmy.
Good luck and as stated above.. turn off the caps please.
replacement wheeels
sorry about the caps-all the wheels were checked at bell tire on their equipment-as the wheels were rotating, i saw the out of round condtion as the wheels were turning-the front end had already been realingned-the manager informed me that since the front end had already been realined that the wheels were the problem-since they were the origninal wheels, they were out of round due to fatigue and being 43 yrs old.
I would just get new wheels then if your sure thats what the problem is.
Since your replacing the wheels anyway, why not get a set of chrome 65-66 styled steel wheels. In my opinion these look fantastic with white letter tires.
http://www.justmustangs.com.au/image...-red-front.jpg
if you can already see the out of round in the shop (and the shop tells you they are no good anymore), I'd go for the new wheel option as well. those magnum 500s as posted above look great on any 64-66 if they suit your taste
