t5 help!!!!!!!
t5 help!!!!!!!
i have a t5 that i bought after i bought it i found out its from a 94 cobra so it has the longer input shaft and tapered bearings insted of the needle bearings like older models what do i have to do to make it work on my car i have a fox body setup?
Pop the top off of it and have a look at the gears and syncro dogs. post good photos I'll let you know what I think then.
I do not know if they make an adapter plate that would allow you to run the 94 trans
What year is your car?
-Gun
-Gun
It will work fine as long as you have the bell housing that belongs to it. The input shaft is 1" longer yes, but the bell housing is also longer. They offset each other so it works fine. I just installed that exact t5 into an 85 fox body and it worked perfect. No issue at all. We did use the clutch fork from the fox though.
yes the shaft is tapered but it works. You dont even have to trim the shaft IT WORKS PERFECT. the shift handel will also sit back 1" and will feel better.
Yeah, like he said. Use the 94 trans you have to use the 94 bellhousing. If you want to use a 79-93 bellhousing so you don't have to cut the shifter hole you will have to change out the input shaft.
Is this going in a fox or a classic?
