Wheels and Ride Height
#121
Finally, here are some recent pictures of mine.
It has GT rear leaf springs and 1 inch lower front springs. The wheels are 15x7 Magnum 500 and the tires are 215 60 15 Yokohama YK520. I love how it looks now. It also rides and handles much better than it did with the BFG TAs. They were 215 front and 235 rear.
The rear shackles removed and the wider white letter tires removed.
#122
#125
2-3" lowering blocks? Sounds like a recipe for massive wheel hop. Why don't you drop it correctly by installing a lowering spring (reverse eye or mideye)? I wouldn't recommend any block thicker than 1". Lowering the front could be as easy as cutting the coils.
#127
If they make lowering spindles for any front suspension other than the mustang 2 I'm not aware of it. Unless you have a mustang 2 up front they won't work. Posting a pic would help us advise you. A 3" block may lower it where you want it but at what cost? Anything worth doing is worth doing right. That's why I suggested replacing the rear leafs with a leaf that lowers the car, if you need another inch, a 1" block is okay. To lower the front, do the arning drop and cut the coils if needed.
#130
Your car looks good. I am looking at the same rim, but 17x9 front and 17x10 for the rear. Have you consider a wider rim before deciding on these?
Thanks
Thanks
