Here are new pictures! I will try and lower it some today if I can. It needs like 2+ dropped in the front.
Hey BA, That looks good with the new wheels. It looks much better in your post drop pics with the nose down some. How did you drop the front, 1 inch lowering springs and shelby drop?
Hey, I just noticed that you have the same issue as I have now. I just bought some 05 bullitts for my 65 coupe and not sure what size spacers I need. Did you end up with a solution for front/rear that worked well? Thanks.
iirc you need 1 1/2 inch spacers in the front and 1 inch in the rear......
69 M code vert,ps,pdb,ac,tilt-swingaway,shaker,351W auto....added fatman 2" drop spindles and 2" lowering block on the rear,kybs,16" TT wheels....other than that it is stock!
just bought these bullits from my friend. they have 275/40's all around that are shredded to ****. new tires will be 255/40 in the rear, and probably 235/40 in the front so i can lower the hell outta it.
