When I put the 8" rear end under it the cables were the wrong length. Wouldn't hook up where they should, so we cut the lines at the rear drums. I didn't need it, but every so often I do wish I had it.
Slip the box end of a 13mm wrench over the cable. It will be tight enough to collapse the tangs and you can remove the cable. (it might take a litttle wiggling)
Thank you Stepman. The information was what I needed. I spend 2 hours and the fitting still did not come off. After reviewing your instruction, I was success in less than 10 minutes!
