DIY Rear Disk Brakes ($200)
01-29-2010, 03:05 PM
why not use explorer/ford racing rear discs? they're a direct bolt on for the big bearing 9".
01-29-2010, 03:08 PM
Is this possible with an 8" rear end?
Nevermind I see you said it think it should work for any rear end. I guess it makes sense that it would.
01-29-2010, 03:46 PM
Quote:
Originally Posted by
NuclearMuscle523
Well, I'm still newb with no clue. ??????
i wasnt trying to be a jackass if it came across that way :/sorry bud
01-29-2010, 04:10 PM
SCAM ALERT! This person is known around the internet for ripping people off. You've been warned.
No, seriously, I still have no clue.
01-29-2010, 04:22 PM
like if it would work with your rearend? or how to do it?
01-29-2010, 04:33 PM
like parts are involved, do I need spindles or something?
01-29-2010, 05:49 PM
jcoby
half the price with warranty to boot. But that Explorer set-up is much much nicer!
EDIT: Also that set-up is for a New Style big bearing rear end and my rear end is the old style big bearing pattern.
no, he listed everything that you will need in the first post, the brackets that weld onto the axle housing, calipers, lines, rotors, dont need spindles, with your drum rear you can use the stock retainer plate
01-29-2010, 09:12 PM
So those brakets are the DIY part. I don't know if I trust my welding skills on a brake component.
01-29-2010, 10:02 PM
Yes these brackets are cut to fit and require welding.
