SSBC Comp R/S Brakes
04-28-2010, 12:31 AM
It'd depend on the pad compounds used and the piston sizes in the calipers.
04-28-2010, 01:58 PM
I am planning on using Hawk HPS pads with either set up.
piston comparison would be the SSBC kit from Summit vs. PBR '04 cobra calipers
thanks 67mustang302!
04-28-2010, 02:25 PM
Does anyone have a picture 11.25" disc brakes behind 17" wheels?
I'm debating whether to get this SSBC set up or go 13" discs with my 17" wheels.
04-28-2010, 02:26 PM
The one with bigger pads and bigger pistons will stop better, but you need enough master cylinder to move the pistons.
04-29-2010, 11:56 PM
If going with this 11.25" 4-wheel disc set up, does the master cylinder need to be changed also??
04-30-2010, 01:49 AM
I just realized this kit has no provision for the e brake, what are you guys doing for an e brake??
thanks.
04-30-2010, 07:30 AM
04-30-2010, 10:00 AM
Quote:
Originally Posted by
Deviousfred
I will be going without.
Good luck passing inspection.
04-30-2010, 01:28 PM
04-30-2010, 02:58 PM
That is a great price for those. I think I paid that much when i bought mine 10 years ago. i got the fronts only(not cross drilled) and they have performed flawlessly since day one.
patchshaffer
Tuner Central
10-05-2015 02:24 PM
Matt's 95 Stang
10-05-2015 07:16 AM
Florida Regional Chapter
09-30-2015 08:04 PM
junior04
09-28-2015 10:53 AM
09-25-2015 06:42 PM
23 ,
67 ,
brakes ,
california ,
comp ,
conditions ,
front ,
hub ,
kit ,
mustang ,
offset ,
powered ,
road ,
sells ,
ss ,
ssbc ,
vbulletin ,
w1202 ,
w12022
