Well, My fastback is home after a spooky 5 hour drive! Suspension time!
Parts can be worn and not necessarily show signs that easily. Especially bushings that can squirm and deform under cornering loads, but appear stable when you move stuff with your arms(which cant apply thousands of pounds of force like cornering does). And yes, a cockamamie alignment can do all sorts of stuff, cause instability, bump steer etc. Bump steer is actually a steering linkage specific problem where the linkages are located in the wrong spot. And the wrong alignment(like typical factory 60's alignments for the no longer used bias play tires) can make a car VERY unstable.
Looking at the car I am starting to think that the front end has been lowered a bit? That could really mess with the bump steer if the springs were cut off without changing the pitman arm right?
Looks nice! Definitely lowered but I like that look myself. My guess would be that the rubbing is from the lowering. Is it when you turn sharp, or just driving straight? At any rate, that's a big concern cause it can be a hazard.
Well, I have no idea what the numbers are for the alignment but the old man did seem to like the service shop and I would guess the thing is not to far out of whack. Even the shocks are new and the car has no tire wear issues.
To be fair to the car I took it for another drive yesterday and really looked at my issues and I think I have it narrowed down.
When two people are in the car the front right tire just rubs slightly when I turn in and hit a bump (and I have a skinny wife) . It seems like a cut spring lowing job?
Bump steer is obvious and pronounced, even on dips in the road.
That dead/flat spot in the center of the steering gear/box really kills it for me.
My steering wheel is a crap "Grant" that does not feel like the best installation.
So, maybe I should just try a Flaming River 16:1 box and some new springs that are a known variable and a fresh alignment...at least then I can have some sorta baseline and know what I have. Then I can decide if I want to spend the money on this particular car for spendy suspension.
If one uses shorter springs should one use any special pitman arm or other parts to reduce bump steer?
What size are those wheels and tires?
Dodgestang has quite a bit of wheel/tire/clearance stuff assembled. See if what you have is listed.
http://www.dodgestang.com/Tire%20Fit...ide%2065-6.pdf
Norm
Norm
I would do a lot more research before you buy anything. If track performance is your goal you need to do a lot of homework, or you will be wasting time and money.
You may start at Gateway classic mustangs. At least they can show recent performance results.
