electrical pulsing
Old 01-07-2011, 04:23 AM
66 tang
66 tang's Avatar
Default electrical pulsing
the car is a 66 coupe and when its running the electrical system pulses, my headlights dim and brighten with the idle of the car, and my amp gauge jumps around, do you guys know what this is? voltage regulator? altinator?
66 tang is offline
Old 01-07-2011, 06:48 AM
ThanksDad
ThanksDad's Avatar
I solved this problem for about $12. Under the hood is a mechanical voltage regulator. Go to your local auto parts store and pick up a electronic one. The mechanical one has moving parts which causes the flickering, the electronic one has no moving parts.
Mine has a silver cover which I like but I'm told you can take the cover off your old unit and put it on the new one for a stock look.
Fastest, cheapest, easiest repair I ever made to my baby.
ThanksDad is offline
Old 01-07-2011, 07:16 AM
hightower2011
hightower2011's Avatar
Sounds like the voltage regulator.
hightower2011 is offline
Old 01-07-2011, 10:05 AM
66 tang
66 tang's Avatar
now is the voltage regulator mounted kind of behind the drivers side head light?
66 tang is offline
Old 01-07-2011, 10:24 AM
mySAVIOReigns
mySAVIOReigns's Avatar
Should be right next to the radiator, near the top, on the driver's side.
Look for the square box on the lower left hand side of this picture.
mySAVIOReigns is offline
Old 01-07-2011, 10:39 AM
66 tang
66 tang's Avatar
coolio! thanks guys, i'll pick one up after work today
66 tang is offline
Old 01-07-2011, 10:43 AM
kalli
kalli's Avatar
Originally Posted by mySAVIOReigns
is there some kind of nasty romour that a fan shroud robs HP and gets your dog pregnant? every classic Mustang I come across is missing it for no obvious reason.
kalli is offline
Old 01-07-2011, 11:38 AM
Gun Jam
Moderator
Gun Jam's Avatar
you would think!
I dont think mine did when I picked it up. maybe the plastic was shotty and after 40 years they all break and no one bothers to replace them.
If the regulator doesnt help then you'll have to look into a grounding issue.
-Gun
Gun Jam is offline
Old 01-07-2011, 02:39 PM
OCHOHILL
OCHOHILL's Avatar
I don't think the 65/6 came with shrouds. Plus, they were so minimal they hardly helped. I installed one with absolutely no benefit. I still have the scar to remember it by. POS in my opinion.
OCHOHILL is offline
Old 01-07-2011, 07:39 PM
66 tang
66 tang's Avatar
so i talked to a dude at napa and he said in order to get an electronic voltage regulator in a 66 mustang it would have to be built into the altinator. does this compute with you guys? is there some part out there that i can put in there and not worry about? or will i have to put a voltage regulator in there every few years?
66 tang is offline
Quick Reply: electrical pulsing
