1970 louvers, HELP
[IMG][IMG=http://img534.imageshack.us/img534/6084/imag0084c.th.jpg][/IMG] Uploaded with ImageShack.us[/IMG]
[IMG]<img src="http://img534.imageshack.us/img534/6084/imag0084c.jpg" alt="Image Hosted by ImageShack.us"/><br/>By <a target="_new" href="http://profile.imageshack.us/user/racingboy1">racingboy1</a> at 2011-01-09[/IMG]
The 3M tape you are talking about is super strong, however for the amount of surface area I believe you have where the bracket is to stick it down, probably wont be enough area without a bolt to do the job. I am sure when you drive those louvers get a fair amount of air turbulence and although the tape is strong (shear stength around 25-35 psi) it's not worth the risk for other vehicles behind you. You could always tape them down if the mount is completely flat to the outside of the car. Then drill through the tape with the louver in place. I don't have a 70 model but the set up of those may allow you to. The 3M VHB tape is waterproof however you would want to silicone right around the bolts. More than likey the bolt and the tape will bond together while you torque it down, waterproofing it. If you would like some of this tape, just pm me with your name and address and type in there "5952". I can send you a sheet of it for free.
Damn that was a big picture. You could go back and edit that post and delete the oversized picture. To make this thread easier to read.
That last one looks good. Very sweet 70 Man! I love those. Is it the light blue or is it white?
