8 inch rear end
RE: 8 inch rear end
It really depends on how you plan to use it, how much traction you have and what kind of transmission you run. An 8" will take quite a bit of street abuse with an automatic. The case is the weak link, even with a set of good quality gears. Throw a manual into the mix with sticky tires and traction bars, and a healthy small block will have the capability to crack the case. The common point of failure is the boss where the small pilot bearing on the pinion goes into the case. Ford knew what they were doing when the equipped K code and larger engined Mustangs with 9" rears.
RE: 8 inch rear end
thank you for the help, as i will have a little over 400 horsepower and a 4 speed toploader, i do not plan on going to the strip or having super wide tires or traction bars, or anything too serious, i think i will be fine with my little 8 inch, but if it happens to break that just gives me an excuse to buy a new 9 inch and again thank you
mungodrums
10-07-2015 04:01 AM
Dragonus18
09-09-2015 01:21 AM
09-01-2015 08:16 PM
