Interior Restoration
02-17-2011, 12:42 AM
I just wanted to double check the process...For all exposed metal under the dash, glove box and doors, along with the plastic kick panels, would you:
1. strip the paint
2. sand with 000 steel wool (would you sand the plastic kick panels?)
3. Clean
4. prime
5. paint (interior paint - spray can)
02-17-2011, 01:19 AM
Anything plastic you can just wash it then use a wax and grease remover and paint it with sem brand dye it works good.
02-17-2011, 09:34 AM
I used Krylon Fusion made just for plastic on my kick panels. Just do light coats until you get the coverage you want.
02-18-2011, 01:37 AM
would I even need to strip the paint off the plastic then? or just do a clean prime and paint on top?
02-18-2011, 02:01 AM
depending on color you might want to use a touch up gun and/or and Air Brush. Rattle cans leave you almost no control.
02-18-2011, 05:42 AM
Quote:
Originally Posted by
67 newb
If it was me, I wouldn't try to strip the paint from the plastic. I would just primer over it and go from there.
02-18-2011, 08:11 AM
If the paint is flaking then remove it if not primer it.
GPR
12-16-2015 12:21 PM
b8checker
10-08-2015 12:55 PM
jrrhd73must
10-02-2015 09:17 PM
b8checker
09-30-2015 07:11 AM
treesloth
09-28-2015 07:03 AM
