Inline 6 2 barrel Carb upgrade Linkage?
Thanks. Do you have a part number/name for the cable you are using? I can only find a 36", maybe that's long enough for how you're doing it. I went to pick up my cable from O'Reilly and it turned out to be closer to 7.4".... I was pretty bummed.
Is this it?
http://www.oreillyauto.com/site/c/de...0&keyword=5657
Is this it?
Is this it?
Is this it?
Thanks. I used a Clifford Performance 2bbl adapter no spacer with a holley carb. I mounted mine backwords from the way everybody else does it. Not sure why thats just the way I did it 8 years ago. The only issue I have is that a I have to run a very shallow air cleaner but it gets the job done.
