Finally made my decision and brought home my 67!
#41
Ya its chilly but im in Ca so maybe low 50 high 40f. Im going to do some more investigating tomorrow.
What do you guys think about getting an edelbrock rpm air gap 4bbl manifold and a matching 600cfm edelbrock for this?
#42
#43
Cam, intake, carb, might take the head off for a porting and heavier springs for the cam.
#44
It was an edelbrock 600cfm electric choke carb. With an edelbrock rpm air gap intake. Unfortunately I didn't do the cam at the same time. I still want one but one of the shops I called wanted to do quite a few other things for preventative maintenance and I decided I would just stick with what I have.
#45
For a cam as mild as the RPM cam, I wouldnt think you need to upgrade too many things, mainly the stock valve springs. But while the heads are apart might as well open up the ports!
#47
#48
When was the last time it was started? If it sat for a long time there is a lot of stuff it'll burn off before it stops. When I started mine this past summer it was the first time in 15 years or so it had been run. Smoked for about 10 minutes before it let up.
#49
It wasnt smoke though, it was steam, which I know is normal, but he mentioned something about overheating and I want to make sure it didnt blow gaskets or do any internal damage.
#50
OK! went for a drive around the block and good news bad news...
Shift kit! Possible 9" rear, I dont know how to tell the difference, I will crawl under it to check. no air bubbles out of radiator , steam gone.
Brakes need rebuilding, steering squeels, (easy fix), front end feels very loose.
All in all Im pleased that I was able to drive it!!!!
