what are my stock heads worth
Old 03-18-2012, 10:40 PM
MonsterBilly
MonsterBilly's Avatar
Default what are my stock heads worth
I am putting trick flow heads on this week. I have my stock 289 heads that have been ported with really good lunati springs, valve job, screw in studs, guide plats and magnum roller rockers.
I am thinking about putting them on CL but dont know what king of price to ask. I actually have over $900 into them.
Anyone think i can get $600 or is that too much
MonsterBilly is offline
Old 03-18-2012, 11:47 PM
OCHOHILL
OCHOHILL's Avatar
Flow numbers or a dyno sheet would help prove what they can make. Otherwise you won't get much for the heads. If they didn't go quickly, I would sell the rockers seperately.
OCHOHILL is offline
Old 03-19-2012, 01:20 AM
oxfordbp
oxfordbp's Avatar
Ill buy them for 200!
oxfordbp is offline
Old 03-19-2012, 02:45 PM
MonsterBilly
For $200 id rather let them sit on a shelf for a future project. Thanks for the offer though.
Old 03-19-2012, 03:56 PM
oxfordbp
oxfordbp's Avatar
Let me know if you come up with a number. I didnt mean to insult you.
oxfordbp is offline
Old 03-19-2012, 04:42 PM
OCHOHILL
OCHOHILL's Avatar
That's a fair offer considering the buys out there on other proven heads.
Monsterbilly,
If you don't post the improvements to the head you won't get anything for them. Were the intake valves replaced with larger valves? What springs are on the head? Pressure at seat? Seat height? Coil bind? pressure at 0.xxx lift?
Chances are the next guy will have to replace the springs too. Assuming the heads and cam were properly matched, the heads need to go with the cam and lifters. The cam may not be optimized for the new combo.
OCHOHILL is offline
Old 03-19-2012, 04:49 PM
TomKat
TomKat's Avatar
meet him half way 300!
TomKat is offline
Old 03-19-2012, 05:08 PM
Coupe
Coupe's Avatar
What year are they? If they are pre-67 they have a smaller chamber, and can be used for a compression bump.
It kinda comes down to who ported them, if it was DIY many consider the heads to be junk, or close to it. Nobody trusts a privateer with a die grinder.
Sell the rockers first and then try and get the $300 for the heads, but considering a running 289 can be found for $400 it may be tough..
Coupe is offline
Old 03-19-2012, 10:04 PM
Starfury
Starfury's Avatar
Yeah, stock heads just aren't worth anything unless they're hi-po's, and even then only to a person who needs a set with your specific date code. You're definitely not going to get the $900 you put into them. You can buy a set of Edelbrock E-street heads for about that price.
Starfury is offline
Old 03-19-2012, 11:21 PM
MonsterBilly
OxFord, Im not insulted in any way.
I know im going to get close to what i have into them. In fact, if I would have known i was going to end up with that much into them i would have bought the trick flows to begin with.
I was more looking for what they are worth than looking for offers.
They were ported at Kelleys machine shop here in Phoenix. They did a nice job, they are 66 heads out of my 66. They have newer valves (same size) and had a valve job done as well as new seals. The springs are Lunati dual springs and I am not sure of the bind but my cam has a .0538 lift (which is pretty good sized and they dont bind with It) the heads also were milled .005 as well.
I will post pics later im too tired from work now.
I will let you know if im interested in sending them your way one i fire up my car with the new heads on it.
Quick Reply: what are my stock heads worth
