I'm using ,26 mig wire, should I change to .30
Old 03-29-2012, 12:51 PM
dmaclaren
dmaclaren's Avatar
Default I'm using ,26 mig wire, should I change to .30
Is that that big of a difference? Will it help me plug and stitch better?
I did the torque box with the .26 and I am on the toe and floor pan next as well as tinman subframe connectors.
The torque box went well. I guess more wire/fill would be nicer.
dmaclaren is offline
Old 03-29-2012, 01:21 PM
lil bull
lil bull's Avatar
heavy metal requires heavier weld wire. You can do it with thinner wire if your good at welding. the whole key it to get good penetration with out a burn thru.
lil bull is offline
Old 03-29-2012, 01:30 PM
JMD
JMD's Avatar
I say if you are doing well with the .26 wire, stick with it. My problem with the MIG process, is that for my tastes, the welds are too bulky on sheet metal. I prefer a thinner bead for less clean up, easier workability, and less distortion.
JMD is offline
Old 03-29-2012, 02:31 PM
ozarks06
ozarks06's Avatar
I used .023 for my sheetmetal work.
ozarks06 is offline
Old 03-29-2012, 04:03 PM
palerider
palerider's Avatar
I used .025 on sheet metal and .030 on heavier metal but as alrady said if you are getting cood penetration .026 is fine.
palerider is offline
Old 03-29-2012, 05:00 PM
boogerschnot
boogerschnot's Avatar
Maybe thats why i kept blowing througg with the.030.. would have been nice to know.. lol
boogerschnot is offline
Old 03-29-2012, 07:57 PM
LynnBob Mustang
LynnBob Mustang's Avatar
My friend welded my sub frames on our '65 coupe this past weekend with .23 wire, he told me to have .30 wire on hand just in case the .23 wire didn't work, but it was fine.
The .30 wire is for heavier metal.
Lynn
LynnBob Mustang is offline
Old 03-29-2012, 07:58 PM
LynnBob Mustang
What size do you work with usually?
Lynn
Old 03-29-2012, 08:46 PM
ozarks06
ozarks06's Avatar
When I bought my welder the guy at the store (an industrial shop bought by Praxair) said the auto body shops use .023 so that's what I used.
ozarks06 is offline
Old 03-29-2012, 10:22 PM
groho
groho's Avatar
welding is a technique that has many variables. the same size spot weld takes longer to fill using .023 than .030, and the shortest duration using .035. The longer it takes to weld that hole, the more heat is transfered to the metal, and possibility of warping. Ideally you want the shortest time welding to minimize the heat zone, with enough current to provide sufficient penetration. I find .030 is the best all-around wire for me on panels and sheet metal, and subframe. I've found if I increase the amp and feed a touch more than expected, and shorten my trigger time, the weld is much better then .023.
groho is offline
Quick Reply: I'm using ,26 mig wire, should I change to .30
