ping during timing?
Old 05-08-2012, 11:59 AM
MetalEd
MetalEd's Avatar
Default ping during timing?
everything I read says to back off if I hear the "ping" while timing my car. What is the "ping" is it like a small backfire? A couple times of the car firing normally and then a little "pop" in the firing?
MetalEd is offline
Old 05-08-2012, 01:12 PM
Iskwezm
Iskwezm's Avatar
you'll hear pinging under a load, not at idle.
Iskwezm is offline
Old 05-08-2012, 04:39 PM
69mach1377
69mach1377's Avatar
If you have a quiet exhaust, you'll hear it while driving and flooring it. With a loud exhaust, you may never hear it.
It's basically knocking, a precurser to a misfire, but not a backfire. I've heard it described as BBs rattling around.
69mach1377 is offline
Old 05-08-2012, 10:16 PM
bradleyb
bradleyb's Avatar
i agree, if it does this at idle, i don't think it is timing related (when I took autoshop back in the day, i was told to tune until slight ping at full load and back off a degree or two, as opposed to just tuning to spec)
bradleyb is offline
Old 05-09-2012, 03:02 PM
jlg2002
jlg2002's Avatar
Pinging sounds like a rattle noise, much like a paint can when you shake it when the engine is accelerated. It is caused by the flame front in the cylinder exploding - typically related to too much timing, carbon deposits in the cylinders or just crap gas.
jlg2002 is offline
mungodrums
10-07-2015 04:01 AM
clowe1965
Carolina Regional Chapter
34
09-28-2015 09:18 PM
StalkerGT
09-25-2015 02:41 PM
09-08-2015 11:50 AM
Quick Reply: ping during timing?
