T-5 difficult to get into reverse
Hey guys, been a while since I've posted anything on here. I've noticed the last few times that I've taken my '66 out, its been kinda tough to get my t-5 into reverse. It grinds a bit when I cram it into only reverse. Also, every now and again, the clutch pedal hangs about halfway up when released. I am pretty sure I just need to get under there and adjust my cable clutch to help it engage more fully. Anyone have any more ideas? I will be putting it up on a lift hopefully later this weekend, given the weather cooperates.
reverse is gonna grind going into gear its not synchronized like the rest of the gears...try putting it in 3rd then reverse should make it a little easier to get in gear. also your clutch linkage could be out of adjustment too
Thanks guys, I'll try all the above mentioned ideas. I believe my clutch needs to be adjusted too because of the sometimes hanging clutch pedal. Also, I've had the T-5 in there for a couple years now and I really hadn't noticed any difficulty getting into reverse until a few months ago, although I hadn't driven it much this Winter either. I am unsure of what year it is. I bought it new about 4 years ago, then after the original installer only filled it to the drain plug (duh!) I had to get it rebuilt, and of course the warranty didn't cover that.
Seems to have worked... I have been sticking it in 3rd or 5th before reverse and so far, not a hiccup. I still need to get underneath and adjust the cable, but that will come with some dry weather...
I have a '91 GT with a T5 that I purchased new. In 21 years of ownership it's ALWAYS been difficult to get into reverse.......I always double clutch it a bit and it pops right in.....been that way since day one.
I can just about guarantee, if you go into first or 5th, i'll not balk going into reverse! Simply stated, It has o do with the gear and shafts.
Happy Motoring!
