Brake ID please
Brake ID please
Chokostang where are you!!??
Dan, you helped me ID my 67 brakes, here is another one for you OR anyone else that knows!
I want to know so I can order the correct bearings for my spindles, proper brake pads, and etc.
Here I are--
The spindles are more than likely C5DA.
By viewing the square/vertical shoulders on the spindles. BUT, the C20A, C3OA C4ZA spindles had the same aspects.
The odd ball C4ZA spindles with the same short steering arms as the
C2OA C3OA, but has the taper for the Tie Rods to fit the 336 Mustang V8 Outers, the Fairlane Spindles (The O in the third position) were the different blunter taper for the Fairlanes.
Bottom Lines, those spindles will fit the K/H 4 Piston Disc brakes as used in all 65-67 Mustangs--Of course as we are viewing.
I guess to find out which you have, Wire brush the upper arm, MOTOR Side, this will tell you which.
Post, or call.
Dan @ Chockostang
Post, or call.
Dan @ Chockostang
Yes, I'll guarantee there are number on those spindles, hard to get, but there.
Dan @ Chockostang
My goal is to know what bearings, outer tie rods and ball joints to order should I need to.
Thanks Dan
Bearings are A2 A6
Grease seals 6815
Rotors 6004 Raybestos, or generic (Same thing) 5406
Calipers will be 65 66 Mustang Fairlane Comet stock 3/8" 4 Piston Caliper (64 65 4400/4401)--(67--4504 4505), OR the 67 4 Piston with 7/16" port--Your choice, all will fit the spindles listed.
Ball joints will be all 62-66 Fairlane--65-73 Mustang--And more.
Tie Rods, WOW, depends on the spindle.
Dan @ Chockostang
