electrical issue
Old 04-17-2013, 11:31 AM
curran67stang
curran67stang's Avatar
Default electrical issue
having a bit of a brain fart here. im not getting spark when trying to turn the engine. i put my multi meter across the coil (with the key in the run position) and got zero volts. then i tried putting the positive on the ignition pole of the starter solenoid and the negative on the block and again zero volts. then i tried the negative of the battery, zero volts. the car cranks, but there seems to be no voltage for spark. im thinking the solenoid is shot. thought about jumping from the battery to the positive of the coil and seeing if it would start that way, but im not sure if that would work. any ideas?
curran67stang is offline
Old 04-17-2013, 03:03 PM
jlg2002
jlg2002's Avatar
If it cranks, the solenoid is OK. You can directly run a wire to the coil + from the battery (this is called hot wiring) and it should start. I suspect you have a bad ign switch.
jlg2002 is offline
Old 04-28-2013, 08:46 AM
curran67stang
tried hot wiring it. no voltage across the coil terminals. positive terminal to cround was ok. next suspect is the coil. looked up the resistance specs and took readings from my coil. seems like my coil is the culprit. trying to find another to test it before buying a new one.
Old 05-01-2013, 02:57 PM
jlg2002
jlg2002's Avatar
The coil grounds thru the points in the distributor so at best you would have pulsing voltage on the +side as the points open and close. If you have an electronic ignition, that ground is controlled by the the ignition unit.
Coil resistance should be just a few ohms on the primary (1.4-1.54 @ 70 degrees F) and about 8000 or so for the secondary.
jlg2002 is offline
chrisdbassplayer
10-13-2015 06:53 PM
Dathan
10-05-2015 05:52 AM
LiquidDrink
09-29-2015 10:06 AM
mrappe
09-26-2015 10:16 AM
jc409
Convertible Tech
09-26-2015 08:28 AM
Quick Reply: electrical issue
