T5 swap success!
Old 05-14-2013, 08:29 PM
Stangman70
Stangman70's Avatar
Default T5 swap success!
Feeling very accomplished, should have some pics coming up later tonight, but I got my T5 in even though its just for mock up. Had a problem with my cross member, bought one from mustangs unlimited (POS), and had to buy another one from Modern Driveline, yes I could have built my own but don't have the space right now. Anywho I was all excited to get my mock up done, swapped in a 9 inch as well so I could get the driveshaft fitment figured out, and I slide my shaft in, oh so smooth, and its so long I can't get the pinion to set on the yoke of the 9 inch. I am thinking I might have to lop off almost 3 inches to get the thing to fit. Anyone else run into this kind of problem?
Stangman70 is offline
Old 05-15-2013, 10:36 AM
69mach1377
69mach1377's Avatar
What are you swapping from?
69mach1377 is offline
Old 05-15-2013, 03:47 PM
Stangman70
Stangman70's Avatar
C4 auto
Old 05-15-2013, 04:01 PM
69mach1377
69mach1377's Avatar
I've read about trimming one inch off, but not 3.
I'll figure mine out in a month or so, swapping out an FMX though.
Old 05-16-2013, 07:13 PM
69mach1377
69mach1377's Avatar
OP, what does the slip yoke look like? Is like others I've seen or does it have a thick disk cast in?
A pic would be nice from anyone who can help?
Old 05-16-2013, 09:51 PM
Stangman70
Stangman70's Avatar
Looks like all the other slip yokes I have seen. Not sure what you meant by the disk part.
Also here is a bad pic of the trans installed.
Found that my total DS length is 60" but my length from the flat of the pinion yoke to the center of the slip yoke u-joint is 50 1/2" does this mean I need to cut 10" off!? Some how this does not make sense to me.
Old 05-16-2013, 10:06 PM
boogerschnot
boogerschnot's Avatar
My support for the AOD swap also sucked.. I cant remember the brand but I kept telling myself that I should have just modified the original.
boogerschnot is offline
Old 05-16-2013, 11:36 PM
Stangman70
Stangman70's Avatar
Booger, glad to hear it wasn't just me that had problems crossmembers. What color is you car?
Old 05-18-2013, 10:10 AM
69mach1377
69mach1377's Avatar
The yoke I saw looked like this...
http://www.google.com/search?q=t5+yo...tm%3B452%3B273
Old 05-18-2013, 07:36 PM
Stangman70
Stangman70's Avatar
Weird, I have never seen something like this on a mustang. That is interesting. Maybe it came off of a truck or something Heavy Duty.
Quick Reply: T5 swap success!
