Big poops
Big poops
Been working on a 67 Coupe and it somehow shifted off the scissor jacke...not sure what happened..
It is now sitting on 3 stands as the drivers side rocker is not attached(replacing off donor).
I'm trying to figure out how to get it re-leveled. I have 2 jacks where the front of the rear springs connect to the frame and have that level.
Any suggestions as to where to go next???
The drivers side A-pillar,firewall,floorpan is not connected(removed to replace).....LOST as what to do
Take that scissor jack and toss it, those should never be trusted to do what it sounded like you were trying to do with it. If you were under the car when it happened, well........ Get the idea?
Please post pics of what things look like now so we can try and help you get the car back up to where it should be.
At least you weren't under the car when it shifted off the jack, so thank god for small favors in giving you a lesson.
Good luck.
Lynn
Good luck.
Lynn
As you can see I'm working on a flat bed trailer,so I don't have to deal with the sand floor.
Have some pics ,but don't know how to get them on here..figured out
The only area I got level is under the rear of car on the frame. There is a area from windshield pillar across that is level but the drivers side is not attached to anything.
I'm trying to level up so I can finish attaching drivers side rocker and A-Pillar, then fix firewall and proceed I hope.
Before it shifted all my measurements were within .001-.005.
I'm only using the scissor jacks to adjust heights.
Appreaciate any suggestions
But the scissor jack was/is part of the problem and needs to go before you continue. It is not stable enough for what your doing, AS YOU FOUND OUT, loose it and get a better jack. You will kill your self or someone else should they go underneath that thing with that scissor jack under it.
Lynn
Lynn
Lynn
Lynn
I nor anyone else goes under the car unless it is completly supported..
Thanks
Foghorn Leghorn
Location: I reside in a near constant state of amazment.
Am I missing something? Are you asking how do you re-level your car? Not trying to be a wise ***, (somebody make a note of this).
If the scissor jack is all you have then you could use chocks of wood & shims placed under the car to crib the whole rig up in place while you are working to get it level.
Put some cribbing under the car so the whole thing can't come tumble turding all the way down.
Yes I need help with getting the car back level, as you see in one of the pics I only got the bottom level at the rear frames. There is nothing in the front on drivers side to put any kind of jack; so I'm dealing with only 3 points.
Hope that is clearer...
Not a flame, and you're waaaay past this point, but why did you start this on a trailer and not a flat ungiving surface. Even when you get it back level, this will change with tire pressure.
Any chance of moving it to a flat surface and starting over,....?
