vibration after letting of gas, 66 289
Old 08-04-2013, 01:17 PM
fb1371
fb1371's Avatar
Default vibration after letting of gas, 66 289
I am noticing that when I am letting off the gas I am picking up a vibration that is not like a tire bouncing but more of a area around transmission area but cant really tell. its really hard to describe how it feels in words. its more of a deep toned type vibration than a sharp rattle vibration . just wondering if any suggestions on which way to start looking. I got under car ( without it being jacked to high) and shook drive shaft but it didnt seem to have any major play. but that doesnt mean it doesnt have when in motion, it did have some movement from front to back is that normal.
fb1371 is offline
Old 08-04-2013, 01:25 PM
Coupe
Coupe's Avatar
A one piece drive shaft should not slide if the u-joints are good. Check both the front and rear u-joints and also make sure the trans mount is not torn. If you do not know how old they are it may be worth the time to take them apart and change em.
Coupe is offline
Old 08-04-2013, 02:17 PM
fb1371
fb1371's Avatar
Thanks Coupe I had thought of changing these out anyway so will get on this and check the trans mount.
fb1371 is offline
Old 08-04-2013, 03:58 PM
Miguel Macias
Miguel Macias's Avatar
im sorry to but in but i have the same problem but i have changed the u-joints and balance the drive shaft and changed the tranny mount and i still get the vibration can you guys help me please
Miguel Macias is offline
Old 08-04-2013, 04:41 PM
Coupe
Coupe's Avatar
Did you check to see if your driveshaft threw its balancing weight off?
Coupe is offline
Old 08-04-2013, 06:17 PM
fb1371
fb1371's Avatar
Coupe which end or area would this weight be located
fb1371 is offline
Old 08-04-2013, 07:26 PM
rmodel65
Yukon Cornelius
rmodel65's Avatar
on the front of the driveshaft its a large ring with rubber in between the yoke...how much play is there between the driveshaft and the bearing in the tailshaft??
rmodel65 is offline
Old 08-05-2013, 10:28 AM
Coupe
Coupe's Avatar
Rmodel, what are you talking about?
Coupe is offline
Old 08-05-2013, 05:26 PM
rmodel65
Yukon Cornelius
rmodel65's Avatar
in the transmission tailshaft there is a bushing its the bearing surface the yoke rides in and out in... too much place=loose tolerance=vibes
rmodel65 is offline
Old 08-05-2013, 05:53 PM
Coupe
Coupe's Avatar
This is what threw me, what rubber ring?
some driveshafts have weights on them...ive never seen a classic with one but over 40 years who knows whats under a car...
Coupe is offline
Quick Reply: vibration after letting of gas, 66 289
