Suspension question
Old 08-28-2013, 08:06 PM
  #21
TexasAxMan
TexasAxMan's Avatar
Iskwezm, right now (after new springs) it is 13.75" from wheel center to the fender lip.
TexasAxMan is offline
Old 08-28-2013, 08:10 PM
  #22
Coupe
Coupe's Avatar
Here is a shot I took of arguably one of the best restored 65 GT350 cars known. Its a fresh build.
Coupe is offline
Old 08-28-2013, 08:17 PM
  #23
TexasAxMan
TexasAxMan's Avatar
Coupe, beautiful car!
If it stays where it is, I'm OK with it. But after less than a mile (we do have a few road humps), I'm sure it will settle more.
Old 08-28-2013, 08:20 PM
  #24
Coupe
Coupe's Avatar
Not my GT350, I wish...I was just a SAAC and watched it get judged.
Anyway, I find this thread confusing because from the one photo you have posted your car is indeed taller than mine. This leads me to think that you are concerned because the tire is too close to the fender lip, this could be caused from alignment shims or, more than likely, a disk brake swap of questionable components (Scarebird etc..).
Coupe is offline
Old 08-28-2013, 08:44 PM
  #25
TexasAxMan
TexasAxMan's Avatar
It's a CSRP Granada swap kit. I haven't had it aligned, so that may be a problem, but these are stock springs and there is only 3/4" from tire to lip. I had a '65 as my first car and I can guarantee you it sat way higher in the front.
I know the caster is off as it doesn't return to center the way it should. The toe in is 1/8" so that should be right. I don't know what the camber is, and maybe (probably) should be adjusted. When I assembled the suspension I just put all the shims back in and tried to make them equal at all 4 points.
I'll try to get it aligned soon, but first I have to drastically reduce the jet size, I'm running a 600 Holley on a 302. I'm guessing I need a few sizes smaller jets. Anyone in Houston good with determining the proper jet size?
Old 08-29-2013, 01:08 AM
  #26
Iskwezm
Iskwezm's Avatar
Is that a new "stock" spring?How much did it raise it up?
Mine sits at 11 5/8" with cut coils.I was going to do the shelby drop and "620" springs, but you said yours was too low.
Iskwezm is offline
Old 08-29-2013, 02:32 AM
  #27
67mustang302
67mustang302's Avatar
All that wheel well clearance....you guys trying to go off roading? :P
67mustang302 is offline
Old 08-29-2013, 07:54 AM
  #28
Coupe
Coupe's Avatar
Grenada kits make the track width wider IIRC. Your car is not sitting as low as you think, its just overly tight at the wheel lip.
Coupe is offline
Gene K
10-21-2015 11:37 PM
GimpyHSHS
09-18-2015 12:27 PM
degner122
09-16-2015 07:09 AM
09-08-2015 11:50 AM
raleigh05GTO
09-04-2015 07:09 AM
Quick Reply: Suspension question
