On and Off Brakes!!!
Old 09-24-2013, 07:28 PM
Falcopilot
Falcopilot's Avatar
Default On and Off Brakes!!!
I installed a CSRP power disc kit in my '68 Coupe. I now have the engine running and need to finally drive the car. The problem is the brakes......I've bled them..........have a good pedal.........but when I crank the car the pedal goes to ZERO!!! No resistance!! As most of you know I installed a 92 EFI 5.0 and AOD........I have the vacuum for the booster running directly off a port on the upper intake. What the heck is going on??? Is it possible there is to MUCH vacuum??? I am NOT a mechanic..........but have done all of this conversion on my own.....so I don't exactly know how the vacuum works.
Anyone got any ideas?
Falcopilot is offline
Old 09-24-2013, 07:38 PM
67mustang302
67mustang302's Avatar
When cranking? It's possible there could be a vacuum pulling the pedal....but usually under cranking the intake is close to atmospheric.
Once the car is running is the pedal really soft? Do the brakes work? It could be an overly powerful booster for the setup.
67mustang302 is offline
Old 09-24-2013, 07:42 PM
Falcopilot
Falcopilot's Avatar
While running. There IS no pedal once it cranks.......like it's not even attached to the car!!
Old 09-24-2013, 10:24 PM
67mustang302
Did you pressure bleed then? Did you bench bleed the MC?
Old 09-25-2013, 05:37 AM
Falcopilot
Falcopilot's Avatar
Yes and yes.
I'm convinced it's a vacuum issue.......I'm gonna start changing some of the vacuum setup and see what happens.
Old 09-25-2013, 06:10 AM
dawson1112
dawson1112's Avatar
You still have air in the lines some place,
I bet if you start the car and put it in neutral you can still push the car. Meaning no brakes. If the vacuum was pulling to hard on the booster it would engage the brakes and the car wouldn't move at all.
dawson1112 is offline
Old 09-25-2013, 06:48 AM
Boogie's_AutoRama
Boogie's_AutoRama's Avatar
How are you bleeding the brakes?
The shade tree method of using a helper to open the bleeder while you hold the pedal down is iffy at best.
Better to use a piece of hose on the bleeder barb with the other end in a cup of brake fluid.
Plus, it makes it a one men job.
Boogie's_AutoRama is offline
Old 09-25-2013, 11:10 AM
Falcopilot
Falcopilot's Avatar
Thanks!! Looks like more bleeding tonight then!
Old 09-25-2013, 11:14 AM
Falcopilot
Falcopilot's Avatar
I AM a shadetree, LOL!! More details on your method please?
Old 09-25-2013, 12:41 PM
dawson1112
dawson1112's Avatar
IF you take a jar like a mason jar and fill it with brake fluid , you can open the bleeder on the wheel and use a small leangth of ruber tubing to fit over the bleeder then stick the other end in the jar pumping the brakes slowly , this will push air out while keeping the other end in fluid when you release the brake pedal it should suck fluid instead of air,
I recommend you use this , it is so much easier.
http://www.autozone.com/autozone/acc...er=601274_0_0_
Or if you want to to do the jar method you can use this
http://www.autozone.com/autozone/acc...ier=46839_0_0_
Quick Reply: On and Off Brakes!!!
