another driveline angle question
Old 12-05-2013, 10:22 AM
groho
groho's Avatar
Default another driveline angle question
Found tons of information regarding normal and 4X4 driveline angles, but very little on lowered vehicles. The question, 66 coupe dropped roughly 2"'s (coils+shelby drop, mid-eyes+ 1" blocks). Knowing you have to compensate for the lowered vehicle, and must have 0*'s of angle with opposing front/rear angles no more than 3* of each. Which is best, raise the tail of the tranny, or raise the pinion nose? The 4.5 leaf should reduce or eliminate the wheel wrap. So, which is best? thoughts, or experiences?
groho is offline
Old 12-05-2013, 11:45 AM
barnett468
barnett468's Avatar
ok, you reduced the angle of the diff and trans to the shaft by almost 2 degrees.
if you raise the trans yoke by around 1" and lower the yoke on the diff by around 1/4" you will be close to your previous angles.
if you raise the trans only you will increase the angle of the shaft at the trans more than you will at the diff because you are not changing the elevation of the trans like you did when you lowered the car, you are changing the elevation of the yoke only, which changes the angle of the entire trans relative to the driveshaft. its a complicated but if you draw it on paper you can easily see what i mean.
barnett468 is offline
Old 12-13-2013, 12:29 AM
MonsterBilly
MonsterBilly's Avatar
You can also get motor mounts that allow you to re a is the engine 1"
MonsterBilly is offline
baddog671
07-26-2016 01:20 PM
Dokilar
15
10-16-2015 08:13 PM
AMAlexLazarus
AmericanMuscle.com
10-02-2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 10:29 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
Quick Reply: another driveline angle question
