68 Mustang crash... Fixable?
Old 12-17-2014, 05:08 PM
  #21
67mustang302
67mustang302's Avatar
The Dynacorn replacement metal parts are actually as good, or better than original. They use a more modern steel (that's actually high quality) and some of the parts are a little heavier gauge than stock parts. Also comes with a weld through primer. I wouldn't trust much of the other new stuff though, since it's usually cheap metal and thin parts.
Also, even a total ball of tangled metal of a wreck can be "fixed." You can buy everything you need to assemble an entirely new chassis from scratch these days. Dynacorn even sells whole assembled chassis for fastbacks and verts, but they're not cheap.
Have it towed to an alignment shop and thrown on a rack. If the alignment is off then you know there's some kind of structural damage. Chances are the strut rod mountings are going to have to be replaced etc. Also, since the door is shoved back you need to check and make sure that it's just the door that moved on the mounts and not the unibody section between the front and rear frame rails or that the front frame rails haven't torn loose from the unibody under the driver's compartment.
And for good measure, you might want to invest in some defensive/performance driving classes (if you can find any in your area). Not only can they teach you to drive your car harder, but they can teach you methods to avoid other people's stupidity. Unfortunately defensive driving is just not taught as part of normal driver's training. Some insurance companies may also give a discount if you've had formal driver's training of some sort.
67mustang302 is offline
Old 12-17-2014, 07:21 PM
  #22
barnett468
barnett468's Avatar
actually hust for general info, the dynacorn material is total c__p . . i have been a dynacorn dealer for around 20 years and dynacorn used to have us test fit some of the panels prior to them finalizing them . . the reason they are making some panels thicker is because it is far cheaper for them to use more cheap metal than it is to use less high quality metal.
barnett468 is offline
Old 12-17-2014, 07:23 PM
  #23
barnett468
barnett468's Avatar
Originally Posted by Matthewap44
Mustang Medic from California said they would fix it all for $9k
i seriously doubt they can do it PROPERLY for that price but hard to say.
where are you located?
Old 12-17-2014, 07:32 PM
  #24
barnett468
barnett468's Avatar
It just needs two new front fender aprons and a radiator support. And of course all the parts that were damaged. But the frame held up surprisingly well
the passenger rear fender apron is bent on top and the hood mounting holes are ripped out.
your front frame rails are also bent as well sas your lower front cross frame rail . . i absolutely positively guarantee it
it needs to be straightened on a frame rack which might be around $1,000.00 in your case.
Old 12-17-2014, 10:26 PM
  #25
Matthewap44
Matthewap44's Avatar
Well today i took the radiator out and put a new belt on and went to start it up and the fuel pump wouldnt turn on... im gonna have to follow the wire tomorrow. whatever this car takes to fix im gonna do it. so far ive come to a total of $3500 for brand new parts and 1-2k for the frame to be straightened. i might actually get it for free. the college i go to has a bodyshop with a frame straightener
Matthewap44 is offline
Old 12-18-2014, 12:48 AM
  #26
barnett468
barnett468's Avatar
left side original headlite housing $400.00
http://www.ebay.com/itm/like/161314231022?lpid=82
right side housing $250.00
http://www.ebay.com/itm/1967-1968-MU...6#ht_22wt_1175
nos grill chrome $230.00
http://www.ebay.com/itm/NOS-OEM-Ford...7#ht_218wt_938
this is original front valance . . the ford service replacemant paets were black and noit quite as good in some cases . . $400.00
http://www.ebay.com/itm/NOS-67-68-19...#ht_137wt_1175
nos bumper guards $170.00 . . the repos are shinier.
http://www.ebay.com/itm/NOS-OEM-Ford-1967-1968-Mustang-Front-Bumper-Guards-/141264024161?pt=Motors_Car_Truck_Parts_Accessories&hash=item20e3fdf261&vxp=mtr#ht_234wt_938
Old 12-18-2014, 10:52 AM
  #27
67mustang302
Not sure about Dynacorn in the past, but their current stuff actually does use a good quality steel and is stamped out of the original Ford tooling (where available). It welds really nice with a flux core welder...something that a flux core doesn't do on low quality metals (the impurities and inconsistencies make it spit and pop and run uneven beads). At least that's been on structural components, can't say for certain about body panels, but it stands to reason they'd be using the same metal.
Old 12-18-2014, 02:16 PM
  #28
barnett468
barnett468's Avatar
well i have no idea if they changed the metallurgy however that woukd make no sense . . if the metal was as good as gords which it is fefinitely not., they would have no reason to to make panewls that are thicker than stock plus they know they are bassically thre only game in town so there is no reason to reason or incentive to make the metal better.
i actually knew a guy that mixed the metal at the foundry that made the metal for all the vehicle mfgs in the 70's and i asked him why mopars are so c__py and rust and he said the metal starts out good then different mfgs have differeny specs for the metal . . fird used the purest metal so theirs was best . .chevy added "cereal fillers" so they could get more yield per ton and chrisler used the most fillers . . for example . . the metal might be $1.00 for 10 lbs and the fillers/additives might be only .20 cents a lb so they can add fillers to get 1 1/4 ;bs of metal for 1.20 instead of 1.50 . . the fillers reduce the structural integrity of the metal and also rust easier.
now, ford made red oxide spoare parts and black promer parts . . the red ones were used for the original cars and were also sold to replace damaged parts . . well they went to black primer and at the same time they changed the metal . . i bought an nos black primer hood for $1,800.00 and i noticed that i could just squeeze it and deform the metal so i weighed it and it was maybe 8 lbs lighter than an originsal goofd, lol.
Old 12-18-2014, 03:51 PM
  #29
67mustang302
The Ford factory metal from the 60's was quite good. People did seem to care about metallurgy a lot more back then. Stuff today seems to be hit and miss though, especially with newer engineering schooling being based on the idea of "good enough" rather than "make sure it never fails."
There are newer alloys that are light years better than what was available in the 60's, but it's an issue of whether anyone uses it...or if they do, how purely is it alloyed. Some of it isn't even that expensive, but people just choose not to use it for stupid reasons like "because we just don't."
Old 12-18-2014, 07:12 PM
  #30
Matthewap44
the insurance company said they'll only pay 50% of the repair bill because i was 50% at fault which is bs because i didnt do anything so i went ahead and called a lawyer. hopefully i can get 9k for the repairs so i can send it to mustang medic in california. they said they can fix it
Quick Reply: 68 Mustang crash... Fixable?
