engine frustration
Old 03-14-2015, 03:20 PM
67mustang302
67mustang302's Avatar
I run Amsoil these days, I think the newer Rotella T keeps getting the formula changed and isn't like the older stuff.
What oil pump are you running and what's your pressure throughout the rpm range?
67mustang302 is offline
Old 03-14-2015, 04:17 PM
barnett468
barnett468's Avatar
Originally Posted by MonsterBilly
Unfortunately I am a pool guy not an engine builder. So I have had the work done for me.
To answer a few questions
I am running new trick flow track heat heads
I use Rotella t oil, I think it is a 40 weight
My oil pan is a stock type pan but does have a magnet oil plug
It's frustrating because I built the dam car to drive it hard and I can't seem to make an engine last.
ok, got ya . . your only option is to find a GOOD engine builder that will give you a warranty.
do NOT use rotella oil . . use regular engine oil.
valvoline vr-1 15-40
brad penn penngrade 1 15w-40
if you want synthetic after you break it in royal purple xpr. 15w-40
barnett468 is offline
Old 03-14-2015, 05:10 PM
Starfury
Starfury's Avatar
I agree with the others: stop using the Rotella. I run Valvoline VR-1 10W-30, mostly because of the high ZDDP content. Although you don't necessarily need a high-zinc oil with your roller cam, VR-1 is still a good quality oil that will take the beating you're going to put it through.
Starfury is offline
Old 03-14-2015, 06:43 PM
barnett468
barnett468's Avatar
actually the zddp protects every moving part of the engine, and most if not all oils made have zddp in them including synthetics and mobil 1 which has around 900 ppm, lol.
Old 03-14-2015, 06:51 PM
barnett468
barnett468's Avatar
all rotella t is now epa compliant and has a small sunburst on the label . . non sunburst labeled rotella is an older formulae with higher levels of zddp . . the new stuff has around 1100 ppm.
Old 03-14-2015, 08:34 PM
MonsterBilly
MonsterBilly's Avatar
I think I am going to buy the ATK 347 short block from summit.
My current 331 is so new it doesn't even have a spot of dirt on it. I bet I will pull it and barly have to wash my hands..
Im tired of spending money on engines...
I really want to try and make Drag week for the first time this year, but if it keeps going this way I will need a trailer with a couple extra engines in it.
MonsterBilly is offline
Old 03-14-2015, 10:22 PM
Starfury
Starfury's Avatar
I can't recommend an ATK build. While supposedly their performance department is separate from everything else, I've seen too many sketchy factory-replacement motor defects from them to have much faith in their quality control.
Starfury is offline
Old 03-14-2015, 11:08 PM
67mustang302
Yeah, that's why I run the Amsoil Dominator, they're generous with the zddp.
And the whole change is based on the THEORY that the cat COULD get damaged by the zinc....yet there's never been a single documented case of it happening. But hey...the government is looking out for us, right? =\
Old 03-14-2015, 11:48 PM
barnett468
barnett468's Avatar
i would NOT do that, they suck.
Old 03-15-2015, 07:09 AM
MonsterBilly
so what then, nut up and buy the 363 from ford racing?
http://www.summitracing.com/parts/fm...e8sBoCpwjw_wcB
or should I look into this
http://www.latemodelrestoration.com/...4CxRoCPnvw_wcB
Quick Reply: engine frustration
