SSBC power Disc brake conversion on 641/2
Old 03-27-2015, 06:32 AM
Docmichael
Docmichael's Avatar
Default SSBC power Disc brake conversion on 641/2
After fitting a SSBC power disc kit to replace front drums, the brakes were superb except that occasionally the brakes behaved as though there were no booster assistance, momentarily alarming!. I suspected an intermittent fault with the booster possibly that the control valve was not allowing atmospheric air in when the brake pedal was pushed. SSBC did not accept there could be anything wrong with the booster. For a couple of years the fault almost entirely disappeared but now it is back again. Has anyone experienced this occasional loss of apparent booster action and can suggest a cause?
Docmichael is offline
Old 03-27-2015, 02:05 PM
guitarman376
guitarman376's Avatar
Generally, some cars are more or less sensitive to vacuum levels. Some cars work fine with a small vac leak, while others go haywire. I would chase down any potential leaks first, to cover all bases. After that I would double check booster connections... It sounds like somethings faulty though since it did it right away, stopped, then started again
guitarman376 is offline
Old 03-28-2015, 07:25 PM
barnett468
barnett468's Avatar
exactly when does this occur?
do you have a big cam?
barnett468 is offline
Old 03-30-2015, 12:23 PM
Docmichael
Docmichael's Avatar
No high lift cam. As it is an intermittent fault it is a bit difficult to be precise as to what the driving conditions are when it does happen. I think it is more common when I hit the brakes hard for a fairly sudden slowdown/stop. In traffic at modest speeds when I am touching the brakes frequently it seems a very rare occurrence and as I say when fault is absent braking is excellent.
Old 03-30-2015, 12:27 PM
Docmichael
Docmichael's Avatar
I did check for vacuum leaks initially and subsequently. Thanks anyway I will go and do a triple check!
SSRFUZZY
Members Other Vehicles
01-06-2016 08:22 PM
musnicki
09-23-2015 07:11 AM
Daddys Girls GTs
09-14-2015 08:46 PM
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
Quick Reply: SSBC power Disc brake conversion on 641/2
