Sputtering when given gas
Old 09-24-2016, 09:44 AM
dmaclaren
dmaclaren's Avatar
Default Sputtering when given gas
So was having some issues starting hot but yesterday it started to sputter when given gas. It will smooth out on light pedal but when given gas it's a sputter/hesistation.
THen at low speeds I got a little back fire shifting down gears.
Is it a carb issue? If so, ideas?
not good at all on carbs.
dmaclaren is offline
Old 09-24-2016, 11:07 AM
MonsterBilly
MonsterBilly's Avatar
Definitely sounds like a carbon issue. Maybe the accelerator pump issue. Just rebuild it. Carbs are easy to rebuild even if you don't know how. Just get a clean work space and a new carb rebuild kit and follow the directions.
Rebut kits are usually about $25
MonsterBilly is offline
Old 09-26-2016, 04:22 PM
bop11
bop11's Avatar
Check your vacuum line to the distributor. SOunds like the Vacuum advance is not advancing the spark when you let off the gas, so it is way retarded.
bop11 is offline
Old 09-27-2016, 06:43 AM
dmaclaren
dmaclaren's Avatar
Okay, I will give those both a try.
Thanks
Don
Old 09-27-2016, 07:18 AM
dmaclaren
dmaclaren's Avatar
Okay, I started with the Vacuum advance since it's not on the carb, path pf least....
I was not able to get any vacuum to accumulate when pumping with the manual vacuum pump. I get the initial vacuum but when I go to pump again the vacuum that applied already is gone that fast. I assume it should not leak air back in and vac should accumulate, yes? So I have to see if I can just get a new diaphragm for the distributor then see where I am at.
Then I still need to test after that I am getting vacuum from the hose from the carb.
Thanks and will post back
Old 09-27-2016, 01:26 PM
dmaclaren
dmaclaren's Avatar
Well, my Mallory unilite is one that I can't get a replacement Vac Adv Canister for it. So I spend smaller money to buy one to just get a vac adv. or I buy something else. MSD is over $400 any thoughts on what to get from like 200 - 300?
Old 09-30-2016, 07:09 AM
dmaclaren
dmaclaren's Avatar
I did not buy a new distributor, I took part the Vac Adv. Canister and patched the diaphragm while I figure out what I want to do.
All is back and working much better outside timing I have to do as well as a carb adj.
Thanks
DOn
Old 09-30-2016, 08:42 AM
bop11
bop11's Avatar
did you use that liquid rubber they have on TV? The one that makes a screen door into a boat? Or, a tire tube repair kit?
bop11 is offline
project85
09-02-2016 03:50 PM
dgadkins
09-01-2016 04:46 PM
DeertayD
08-31-2016 12:32 PM
Jon Lequaid
08-30-2016 08:36 AM
TailonM
08-29-2016 06:49 AM
Quick Reply: Sputtering when given gas
