C4 Problem
RE: C4 Problem
i have a 69 fastback that had a 302 and has a C4. the problem i had was that the shifter would slip around and wouldnt lock. would slide from P down to 1 and back without pressing the button. if thats the problem you have try checking the bolt/nut under the shifter plate. if its a different problem maybe the tranny needs to have a gear or two replaced
RE: C4 Problem
Did check your fluid level and vacuum line to the trany? If all is ok try a can of seafoam trans tune it works wonders.
cleans the valvebody and trany internals. If you use it put about 200 or 300 miles on and flush out your trany and put in a
new filter and fluid.
We have used it many times and have had great results.
RE: C4 Problem
Will not go into gear
my tranny wouldn't shift into drive (or any other gears) when i moved the shifter to the position...
it was the seals that were bad in mine...i had the tranny rebuilt with a mild shift kit about 2 years ago and not a problem since.
i've heard others having issues with these seals also...
RE: C4 Problem
if it isn't low, try pennzoil synchromesh, works wonders. i had a celica and it would grind all the time, but it worked like a new tranny when i put that synchromesh in it. find it at autozone. i tried expensive redline gear oil, and that **** didn't even work. go with the yellow bottle!
RE: C4 Problem
im sure its just low if it worked good before it was stored. alot of times on fords the pan gasket will leak from sitting and then it will spill its trans fluid and wont have enough to get going. and for a couple of your guys post it sounded like you guys think his tranny is a stick so if you dont know a C-4 is a automatic.
