Vintage License Plate Restoration:
In Texas, you can use a vintage license plate that matches the year of your classic car or truck as long as you have two plates in good condition with the proper colors. You can register them as either Classic Car which requires you to re-new the plates every year, or as Antique plates which are pro-rated on a five year cycle. Registering them as antique plates only requires one plate on the car (even though you need both of them to be approved at the county tax office) and you do not need a vehicle inspection sticker anymore. As antique plates, you are supposed to only use the car for parades, car shows and club activities, but I have used them on a few of my vehicles for years and the police really have not bothered me when I use the cars for a regular drive around town.
I had a couple of pairs of plates that were in nice condition, but they had a few nicks and dings in them. The county tax office said that for the plates to be approved, that I had to touch them up. I decided to totally repaint them and this is the process that worked the best and looks awesome:
Here is the plate I started with:
Regular paint remover makes quick work of stripping the old paint off:
A wire brush gets all the old paint off:
Small dings can be worked out with a hammer and dolly. Filler may be needed on bigger dents. I used polyester primer to prime the plates:
We now need to paint the plate. The numbers and letters are white so I painted the whole plate white with catalyzed urethane:
When the paint is dry, I applied 5 coats of clear over the white:
When the clear was dry, I applied two coats of black basecoat over the clear:
The next thing to do is to very carefully sand through the black base coat to reveal the white numerals underneath. I use a sanding pad and 1200 grit sandpaper with lots of water:
Since we applied 5 coats of clear, there is no chance of sanding through to the white underneath. Start with one numeral at a time until the edges are as nice as you want them:
When all the numerals are to your liking, you can apply a couple of coats of clear over the whole thing. The clear will bring out the shine in the black and the white and protect the whole plate:
Very nice, though very time consuming. Great write up.
For someone lazy like my self I just bought a replica of my plate (california) they run any where from $55 to $80 bucks and the plate is in mint condition when all is said and done
http://www.licenseplates.tv/license-plates.html
(you can go with your current plate numbers to avoid the hassle at the dmv)
