sub frame connectors for vert
ok, im looking to stiffen up the car a bit, and i hear that i should start with subframe connectors. for vert specific models, what's some fo the ones you guys went with (that have them)? i know when putting them on, everything should be level. so im going to start calling around. also wondering what kind of price range i should be looking at? i dont want to get ripped off either. i have a 92 gt vert basically all stock (although i have ford "c" springs that havent been put on yet), and im in the MD area. thanks guys.
RE: sub frame connectors for vert
i'm going to use maximum motorsport's weld-ons when i do it, i emailed them and they said the ones for a hardtop and 'vert are the same. i have a '95 though so i'm not sure about your car. that is the best thing you can do to stiffen your car up though. just make sure you get the weld-on kind, not the bolt ons. and make sure the car is on the wheels when you weld them on, not on a lift, because you want the car sitting in its natural state when they get welded on (this is especially true for a 'vert).
yeah they are the same....but i know on the verts you have to grind off a rivet or something on one end........im looking into blue oval industries sub frames,upper,and lower control arm package for 165 plus shipping. I know they are prob not the best but im not going to the track or anything.
http://cgi.ebay.com/ebaymotors/79-98...56817963QQrdZ1
Welded subframes a must. I have MM, and they work great.
Here's a pic:
https://mustangforums.com/photo.asp?...Type=6&apage=1
Here's a pic:
ok, so i have heard that MM connectors are really good. but like iamvillani, i was checking out the ones from blue oval. now do you really think there is much difference? essentially arent they all just metal that adds rigidity (is that a word) to the body? just seems like the kit from blue oval adds more for your money since it comes with the control arms. any other input would be appreciated.
ORIGINAL: ebxgsxr
However, given a choice, I perfer to stay with on manufacturer... better chance that future mods will actually fit properly. Since MM sells virtually EVERY Mustang suspension product you could ever need. I recommend MM.
Blue Oval industries has a pretty good package on E-bay for rear control arms (Upper and lower), and SFC for like $200 or something like that. If you are going hard core I don;t know that they would be the best, but for us that don;t visit the track very offen it is not to shabby
