Sponsored by:
Sponsored by:
I've tried every cleaner with no luck?!?!?!
Old 12-09-2006, 02:29 PM
tuhker
tuhker's Avatar
Default RE: I've tried every cleaner with no luck?!?!?!
IT's not really green, more close to black. Yes it is all over the top but some spots seem to be worse like you can see in the pictures where the bars under the top are pushing up, there are no stains there. ???????
tuhker is offline
Old 12-09-2006, 07:14 PM
Poobs
Poobs's Avatar
That may not be a stain but the actual color of the material showing thru. The top coloring may be erroding away because of UV or acidity of rain etc.
Try acetone in a small out of the way spot.
It may not be worth it but the top can probably be sprayed or dyed. Look for outfits that dye boat sails or a good body or reopulstery shop
Do a search in google
Poobs is offline
Old 12-10-2006, 12:39 AM
tuhker
tuhker's Avatar
I don't think it came with spots and stains from the factory but maybe i'm wrong.
tuhker is offline
Old 12-10-2006, 12:55 AM
GreyStang
GreyStang's Avatar
Well, if you've tried all the best known remedies to clean it up to you liking & so far no good, then perhaps the next thing to do is go to an upholstery shop & let them give an estimate/opinion. I've got no other ideas more than have already been mentioned. Good luck with it
GreyStang is offline
Old 12-10-2006, 02:18 PM
tuhker
tuhker's Avatar
I am about to go to Wal-Mart and get a few new ideas. I'll post the results. Thanks for all of the help!
tuhker is offline
Old 12-10-2006, 02:20 PM
TwotoneVert
TwotoneVert's Avatar
What about a steam cleaner like you would use for upolstery?
TwotoneVert is offline
Old 02-28-2007, 07:13 PM
mchipman
mchipman's Avatar
I have the same color top and it looked worse than yours. Bleach and a good scrub brushtook it off, except for the part under the rear window. Like what Poobs said I can see the Black underneath showing through in that one spot.
mchipman is offline
Old 03-05-2007, 12:10 PM
kenv
kenv's Avatar
If worse comes to worse, you can get a new top. I thought they were very expensive, however, the shops in my area will install a new top at this time of the year for $550. Thatis reusing the rear window. They told me to add another $200 for a new one with the defroster. If I get a few bucks, mI`m going to get rid of my tan top, & get a black one put on.
kenv is offline
Old 03-05-2007, 01:08 PM
TwotoneVert
Try that new Arm and Hammer erasor sponge. Maybe something as simple as that will help. They advertise to remove mold and mildew. Its worth a shot.
Old 03-23-2007, 02:58 AM
mitchedwards81
mitchedwards81's Avatar
will scrubbing it with bleach mess up a black top cause i have the same prob on my 89 the tops only 4 yrs old
mitchedwards81 is offline
Quick Reply: I've tried every cleaner with no luck?!?!?!
