Sponsored by:
Sponsored by:
convertible owners beware
Old 07-05-2007, 05:35 PM
wepinsf
wepinsf's Avatar
Default convertible owners beware
about three months ago the convertible top assembly on my 05 V6 "broke". i'm still not sure what happened but believe it was the frame and know that several serious pieces of steel were bent. the dealership hasn't been forthcoming on what went wrong but supposedly there's a tsb out on the problem. the dealership told me they cut ties with the vendor that made the assembly and to date haven't been able to find a replacement top. the last one they found didn't fit. anyone else out there experiencing the same problem? major issue and likely thousands to fix if not covered by warrenty. one garage i took it to said they would basically have to disassemble the car to repair the problem.
wepinsf is offline
Old 07-09-2007, 05:10 PM
Abom
Abom's Avatar
Default RE: convertible owners beware
Ummm, is this not covered by factory warranty ? Very simple, bring it to a Ford dealer and say "fix it", end of story. They will replace the top at no charge(assuming it's a warranty claim and you didn't stand on it or something), and that's that. I have the same model as you, '05 V6 convert, and I have not had any issues with it. Again, take it to a different dealer and get them to fix it. Sounds like your dealer is full of BS.
Abom is offline
Old 07-09-2007, 05:30 PM
wepinsf
wepinsf's Avatar
you are right that it should be simple since it's covered by the warrenty and you're probably right that my particular dealership is full of bs.
the real issue tho is that three months later my car is still sitting at the dealership because ford can't find a replacement as they no longer have a contract with anyone to make the top. the latest is that they may have located one in phoenix. we'll see but the last one they found didn't fit.
i'd hate to think what would happen if the warrenty had expired and this happened especially given that this is a design problem with a tsb out on it.
certainly appreciate the feedback.
wepinsf is offline
Old 07-09-2007, 10:15 PM
bigmike78
bigmike78's Avatar
I hope you have a loaner. If it's been that long I would be jumping someone about fixing it or getting me a different car. I had my F-150 in the shop a long time ago getting a new rear-end in it. After two days of not having a truck I was in there bitching. I left the lot with a year newer pickup. Which then they had my truck fixed with a new rear-end within three more days.
Dealerships, could give a **** less about warrenty work. If two guys came in with the same car same problem but one was paying to have his fixed his would get done first. Sorry to rant my cousin works at a dealeship and also I've had work done there and mine was always last getting fixed before paying customers.
bigmike78 is offline
bigmike78
bigmike78's Avatar
Sorry it posted twice
Old 07-10-2007, 12:09 PM
rkmert
rkmert's Avatar
Same problem here. The dealer said one piece broke which in turn caused others to bend and break. I luckily was able to manually raise the top and get it locked. They said they had seen it happen before on a couple of 2005's and would cover it completely under warranty. That was three days ago, still waiting for a call when the parts come in to fix it. I'll keep you posted.
rkmert is offline
Old 07-11-2007, 05:03 PM
wepinsf
wepinsf's Avatar
sorry to hear this happened to you. would appreciate hearing how the search for parts goes for you. after ten weeks i'm still waiting and i'm not that happy about putting the same assembly as the one that broke back in.
wepinsf is offline
Old 07-12-2007, 02:21 PM
wepinsf
wepinsf's Avatar
Well, the nightmare continues. The dealership claimed two weeks ago to have located two assemblies. Turns out both of them are USED assemblies. So we are back to where we were ten weeks ago. There's now talk from the dealership about a August release date for a back order. First time I have heard that one and heightens the feeling that I've been getting the run around this whole time.
wepinsf is offline
Old 07-12-2007, 03:00 PM
05RedHead
05RedHead's Avatar
I imagine I have the same problem. I went to go put the top up, and it just went straight up in the air!
Luckily I got it down and locked.
I took it to the Ford dealer (still under warranty) and they told me that it wasn't going to be covered! It was going to cost over $2,000 in parts alone! They said it was because "obviously" it was opened while moving, when 1. That's not the case 2. It's not posible to open it above 3 mph or whatever's in the manual.
Took it to another dealer about an hour away, and it's now covered under the warranty, but we're waiting on the part. I guess it's something with the side-arms (same things, one broke which caused the other to break). And yes, there's a TSB out, and Ford is re-engineering the part, which is why it's on back-order. At least this is what I'm told. So, I'm driving my car around still at least, just waiting for the part [:@] Kinda sucks it's summer and I can't have my top down though.
05RedHead is offline
Old 07-13-2007, 10:47 AM
rkmert
rkmert's Avatar
That's exactly what happened to me. It's now been 1 week and I've heard nothing back about the parts from the dealer.They told me a week to 10 days so I'm going to give them until the middle of next week and then begin my assault. Ifany knows where I can find that TSB on the top please forward the info.Thanks.
rkmert is offline
Quick Reply: convertible owners beware
