Forum Issues and Feedback Discuss any issues you are having with using Mustang Forums here.
Shuddering
Old 02-24-2017, 10:05 PM
Brokengun
Brokengun's Avatar
Default Shuddering
From a standstill and slowly taking off, the reared shudders for a couple of seconds and stops as I continue to drive on. Feels like your riding the brakes. Doesn't do it everytime , but does it more when the car is on an incline. Anyone have any ideas.
Brokengun is offline
Old 02-25-2017, 03:13 AM
99GTvert
is my username.
99GTvert's Avatar
What year and engine/transmission? This should be moved to a tech forum but not sure which.
99GTvert is offline
Old 02-25-2017, 07:05 AM
Moderator
JimC's Avatar
So your computer is doing this when you log in to the forum?
Like was said, you are in the wrong section - this isn't for problems with your car. What year and engine are we talking about and it can be moved to the proper section.
JimC is offline
Old 02-25-2017, 08:00 AM
99GTvert
is my username.
99GTvert's Avatar
I wonder if its an older car that may need the ignition serviced, new plugs or distributor etc. That could cause a misfire. Maybe the fuel filter needs to be replaced if its clogged and old. If its a newer car though then I dunno, doubt it would be ignition related. If it was something in the rear end, my guess is it would do it every time and not intermittently unless an ABS sensor went bad and gripped the brakes.
99GTvert is offline
Old 02-26-2017, 08:29 PM
Brokengun
Brokengun's Avatar
this is on a 2009 gt with a 4.0. Plus new to this site and not sure how to switch to a tech forum.
