Sponsored by:
Sponsored by: DashLynx
This is how you disable the seatbelt reminder on your Ford:
Old 06-12-2004, 07:51 PM
mdvaldosta
I ♥ Acer
mdvaldosta's Avatar
Default This is how you disable the seatbelt reminder on your Ford:
This is a copy and paste from this forum, I figure lotsa people would like to know this. Should work on all newer Fords, but not positive.
One time disable
Any time the safety belt is buckled and then unbuckled during an
ignition ON cycle, the BeltMinder will be disabled for that ignition cycle
only.
Deactivating/activating the BeltMinder feature
Read steps 1 - 9 thoroughly before proceeding with the
deactivation/activation programming procedure.
The BeltMinder feature can be deactivated/activated by performing the following procedure:
Before following the procedure, ensure that the following conditions are met:
• The parking brake is set.
• The gearshift is in P (Park) (automatic transmission) or the neutral position (manual transmission).
• The ignition switch is in the OFF position.
• All vehicle doors are closed.
• The driver’s safety belt is unbuckled.
• The parklamps/headlamps are in OFF position (If vehicle is equipped with Autolamps, this will not affect the procedure).
To reduce the risk of injury, do not deactivate/activate the Belt
Minder feature while driving the vehicle.
BeltMinder activation and deactivation procedure
1. Turn the ignition switch to the RUN (or ON) position. (DO NOT
START THE ENGINE.)
2. Wait until the safety belt warning light turns off. (Approximately 1–2 minutes.)
• Steps 3–5 must be completed within 60 seconds or the procedure will have to be repeated.
3. Buckle then unbuckle the safety belt three times, ending with the safety belt unbuckled. This can be done before or during BeltMinder warning activation.
4. Turn on the parklamps/headlamps, turn off the parklamps/headlamps.
5. Buckle then unbuckle the safety belt three times, ending with the safety belt unbuckled.
• After step 5 the safety belt warning light will be turned on for three seconds.
6. Within seven seconds of the safety belt warning light turning off, buckle then unbuckle the safety belt.
• This will disable BeltMinder if it is currently enabled, or enable
BeltMinder if it is currently disabled.
7. Confirmation of disabling BeltMinder is provided by the safety belt warning light flashing four times per second for three seconds.
8. Confirmation of enabling BeltMinder is provided by:
• The safety belt warning light flashing four times per second for three seconds.
• Followed by three seconds with the safety belt warning light off.
• Once again, the safety belt warning light will flash four times per
9. After receiving confirmation, the deactivation/activation procedure is complete.
mdvaldosta is offline
Old 06-12-2004, 11:32 PM
horatio102
horatio102's Avatar
Default RE: This is how you disable the seatbelt reminder on your Ford:
Or just unplug the wires going to the seat belt buckle. Used to work for me.
horatio102 is offline
MustangGirl98
08-02-2016 08:10 AM
Florida Regional Chapter
09-30-2015 08:04 PM
08-28-2015 01:11 PM
chain
08-17-2015 08:52 AM
Quick Reply: This is how you disable the seatbelt reminder on your Ford:
