13's with simple bolt ons..some say no and I say yeah
#51
RE: 13's with simple bolt ons..some say no and I say yeah
When I said "simple" I meant pullies,gears, exhaust, K&N filter and timing bumped to 14*
No induction or valve train changes.
You can include gutted interior but I don't think that's necessary for 13's
BOSSMAN....I'm right there with you doing things in the dirt.
MD, I consider gear changes simple because you can take a car to a shop and have them do it for you for about $500...or...do it the hard way and swap rears in your driveway which can be done in a weekend.
#53
Its very possible, Im in 13's and basically have all bolt ons, prett much every bolt on except upper/lower intake.But with Headers, H-pipe, FLows, Gears 3.55,subframes, timing 14*. youll be in 13's, my friends 91 Notch went high 13's with those bolt ons, on stock tires n' everything stock except what I listed.
#54
we always kept stock headers with the stock heads. 1 5/8 headers slowed one of "our" first cars down, so we never used aftermarket headers in all our stock 13 sec mustangs
#55
Im havin a tough time believin the 103+ trap speed outta just an extra 20 or 30 hp
As far as "SIMPLE" bolt-ons, well I suppose that depends on what you compare it to. I can swap gears in 2 hours, a cam in 3 hours... may be a bolt-on but its not whats considered "simple".
The mods slo93 posted are simple mods, and certainly running 13.'s with bolt-ons is impressive. Cutting a 1.9 60' of stock tires is impressive - definately takes driver skill to do that - but - driver skill isn't gonna get you a 103+ mph trap speed - thats all about hp to weight ratio and your trapping faster than cars with twice the mods... 50 more hp... interesting to say the least
#56
ORIGINAL: mdvaldosta
#58
no but trap speed is an indicator of horsepower - I've seen cars run 13.5 and trap at 110, really depends on the 60'. A large part of the 1/4 time is traction, probably just as important as hp. A set of tires can knock off a full second or more on some cars. Add gears and traction and you've got a 1/4 killer - so simply looking at an E.T. will show you NOTHING about its horsepower. Trap speed is the real indicator of power, trap speed is largely independant of driver skill and traction - and the claimed trap speed is what looks fishy. I can believe a phenominal 1.9 60', and the trap speed matches what would be expected of a 13.6 car with a 1.9 60'... the problem is I don't beleive the trap speed, which is why I don't believe the time (with just those mods listed that aren't worth but around 25 hp).
Once again, I beleive its very likely that you could run 13's in a 5.0 with just bolt-ons... but not a cat-back, h-pipe, and pulleys... I believe, with my experience, that it will take soem sort of sticky tire and gears to do it. A 1.9 60' is about whats to be expected with drag radials on a stock 5.0 - so add some gears and some bolt-on's and your there - but at a trap speed of maybe 97 - 98 mph ON A GOOD NIGHT. to pickup 5+ mph would take probably another 40 hp.
#59
hey,MD what about a 108 trap? is that 12.3 territory?
my dad's 89 lx hatch is bone stock except for a h-pipe,and glass packs.(don't ask)
i vote to make his car a guinnie pig.................
#60
If you know what your doing well enough a Supercharger is a "simple bolt on". I think if you buy a 5.0 just for what most think of as "simple bolt ons", I'd say you bought the wrong car. For as cheap as you can get a 5.0, H/C/I or a S/C arent that far out of reach.
