engine cleaner
RE: engine cleaner
CD2 engine detailer. at least i think thats what its called. comes in an aerosol can. you can usually find it at auto zone or places like that. just make sure you cover your electrical system and you should be fine.
RE: engine cleaner
get gunk engine degreaser its the best and use a pressure washer and if possible use a blow gun to dry it all off the simple solution is just to go to your local shop and ask for an engine shampoo i do a lot of them at work and they always come out nice and i just use a can of gunk and cover everything from top to bottom then spray it down with a pressure washer then dry.
try to avoid the plugs, coil, dist. and battery connections from direct pressure
AmericanMuscle4.6GT
11-10-2015 02:06 PM
TfcCDR
09-14-2015 12:08 PM
