Sponsored by:
Sponsored by: DashLynx
Auto Faster? Stick faster?
Old 03-03-2005, 12:53 PM
2k5pony
2k5pony's Avatar
Default Auto Faster? Stick faster?
You have 2 identical stock cars built in the last 10 years except one is Auto and I one is stick...Once again let me reittarate Identical. Both cars are functioning as they should. Which car is faster in the 1/4 mile? I think the answer is obvious lets see what everyone else thinks........
2k5pony is offline
Old 03-03-2005, 01:01 PM
C/Note
I ♥ Acer
C/Note's Avatar
Default RE: Auto Faster? Stick faster?
id say the stick if you know how to drive,,but auto more consitance,,,haha
C/Note is offline
Old 03-03-2005, 01:04 PM
5.0mustang5speed
I ♥ Acer
5.0mustang5speed's Avatar
if both have the same tracction...the stick will be faster
5.0mustang5speed is offline
Old 03-03-2005, 01:05 PM
2k5pony
2k5pony's Avatar
Heck NO...First off my car is stick. Just because its more fun to drive. No one will shift better than the computer. I dont care how good someone thinks they can drive the computer wins. If you take a look at a Dino sheet someone good at shifting will loose 90 percent of HP at the rear tire. An auto will loose less than 40 between gears. I think the answer is obvious...
2k5pony is offline
Old 03-03-2005, 01:07 PM
Obsol3te
Obsol3te's Avatar
A built auto will be faster in the 1/4 of course.
But the power loss from the stock auto really puts it down from the factory.
Whatcha smok'n there?
Obsol3te is offline
Old 03-03-2005, 01:09 PM
96SilverLT1
96SilverLT1's Avatar
Thats not the point at all. It doesn't matter much how fast you shift. It's when you shift that make s alarge difference. you can control the shift points in a stick. You also have less loss from the tranny and no converter slip. The stick will win out. They always do. Consistncy is only a factor if you can't drive. If you can pull the same RT's and 60 foots in a stick you will be consistent.
96SilverLT1 is offline
Old 03-03-2005, 01:11 PM
2k5pony
2k5pony's Avatar
Looks like we are a bit off topic remember cars are totally identical except one is auto and one is stick. Obsol3te same identical car ect.....
2k5pony is offline
Old 03-03-2005, 01:19 PM
Obsol3te
Obsol3te's Avatar
ORIGINAL: 2k5pony
Yes, I'm saying the Auto makes less power than a manual car.
Obsol3te is offline
Old 03-03-2005, 01:23 PM
2k5pony
2k5pony's Avatar
The power loss to the rear tires between shifts clearly makes up for any loss in the xmission.
2k5pony is offline
Old 03-03-2005, 01:28 PM
96SilverLT1
No it clearly does not.
But why ask a question that you have already desided the answer?
Quick Reply: Auto Faster? Stick faster?
