Check Engine Light 91 5.0 I have the engine codes
I apoligize for double posting, however, my car is getting worse and I want this post to be seen.
I grounded the STI connector to negative, turned the engine on and these are the results of the "check engine" light blinking:
4 blinks, engine reved to 1500rpm for 45 seconds, then dropped to 1000rpm for 5 seconds, then back to 1500rpm then 1 blink, 3 second pause, 9 blinks, 1 second pause 1 blink, 3 second pause, 3 blinks, 1 second pause, 3 blinks, 3 second pause, 9 blinks, 1 second pause, 1 blink, 3 second pause, 3 blinks, 1 second pause, 3 blinks.
so it blinks a 91 and 33
Thanks guys,
Rich
Thanks guys,
Rich
RE: Check Engine Light 91 5.0 I have the engine codes
Thanks for that info. Where did you find this? do you have a link? or book? anything? I would say a majority of my posts on here have been from needing help with engine codes...
Never mind I found this link for anyone else who may need help translating their engine codes:
http://autorepair.about.com/library/...bl-dtcs-79.htm
now, does anyone out there know what these mean??
code #33 EGR Valve opening not detected.
code #91 HEGO sensor cicuit indicates system lean (left HEGO)
