where to jack up the engine
I am changing motor mount on my 93 lx 5.0 i was wondering should i jack up the engine on the oil pan and if so should i do it up front by the cooling fan or towards the rear by the tranny???? any help would greatly be appreciated
RE: where to jack up the engine
what about lifting it with a motor hoist? or just lifting it on one side...you wont have to lift it that much to change the mount....couple strong friends and a long board.
For around $100.00, you can get an engine brace/hoist. It goes across the engine and sits on the inner lip of the fenders. You attach it to the engine with a big J bolt to the engine. You can raise the engine with a wrench then. I used to be Assist Gen Mgr for a franchise of shops. We used them all the time.[sm=gears.gif][sm=gears.gif][sm=icon_rock.gif]
[IMG]local://upfiles/17569/44327DDC32F64BE89C8460D8E1E0222F.jpg[/IMG]
ORIGINAL: mkspeed26
u can put some wood on a flat spot on the pan, and then jack it. but dont jack it directly on the pan.
this oil pan made it easy to do on mine . ya, engine hoist is the best way, but not on some chebbies! ....stupid rear distributor.......
[IMG]local://upfiles/3799/15D485606DA649BDB7DA30361060F3CF.jpg[/IMG]
THanks for all the help guys got one sid edone tonight. would have gotten them both but appears the rear bolt was missing on the pass side. Come to find out the hole is stripped out my buddy is bringing over a tap tomorrow night so we can finish. bout mounts had one break on each by the rear bolt hole on drivers side and front bolt hole on the pass side. i am glad i noticed this before i ended up with some serious damage. Thanks again
AmericanMuscle4.6GT
11-10-2015 02:06 PM
