car leans to the left
06-12-2005, 11:59 AM
my 69 mustang leans to the left what might be the problem
[IMG]local://upfiles/18070/B82C2B13FDE44CFC800B8AFD1AAF38D4.jpg[/IMG]
06-12-2005, 12:19 PM
Moderator
RE: car leans to the left
Its very likely that its a suspension problem. Your springs might be at different rates, the right ones may be higher. Or maybe you blew something? Just check out your suspension components.
06-12-2005, 12:23 PM
I ♥ Acer
check to see if the rubber isolator is still in springs
06-12-2005, 01:23 PM
Could be a damaged shock![:@]
06-12-2005, 01:42 PM
I ♥ Acer
check to see if you have equal air pressure in right and left tires. could be allignment, suspension also.
06-12-2005, 08:02 PM
Site Mod
When it's sitting or when you launch?
Air bags can solve your launching problem. If not, the springs could simply be installed in a different location (should all be "pointing" the same way) which can cause a slight cant to one side.
06-12-2005, 10:05 PM
have you made sure none of the leaves are broken?
06-14-2005, 09:28 PM
it was my tires some joker at the sales place put smaller tires on the left side
06-14-2005, 10:41 PM
I ♥ Acer
ooo. that is real bad for uneven wear as well. did you replace the tire?
06-14-2005, 11:50 PM
Retired MF Moderator
Quote:
ORIGINAL: bloodflow
LOL at least it's an easy fix.....I was just going to say that a really fat guy probably owned the car before you [8D]
Fast-Hands
08-19-2015 06:54 AM
chain
08-17-2015 08:52 AM
cvarner131
08-17-2015 07:38 AM
92 5.0stang
08-13-2015 06:46 AM
Milan Dragway
08-12-2015 03:43 PM
